Logged when the size of Identity database reaches to high memory usage level. Before adding any new information in identity management, check for memory availablity is performed. If 80% or more of the maximum allocated memory is already used and new information is to be added to the database, this EMS is generated. This can be a temporary condition as memory is released by deleting stale database entries periodically.
This message is for informational purpose, and does not indicate any problem. However, admin may want to check the configured memory size for identity database and increase the memory size, if required
Info
Current memory usage %memUsed% Kbytes, %percMem% percent of %maxMem% Kbytes
| Name | Type |
| memUsed | sInt |
| percMem | sInt |
| maxMem | sInt |
